  • 1 Vote(s) - 3 Average
40-155 tuner grommets
Hello. Can anyone confirm that the 'hippo' grommets on the Renovated Radio site are the proper replacements required for the 40-155 tuner supports? I tried to go by the dimensions but mine are so badly distorted I cant be positive. Although, these look to me to be the best candidate.Thanks. Mike.
40-155 tuner grommets - by Squid100 - 05-07-2020, 11:05 PM
RE: 40-155 tuner grommets - by Nathan Slingerland - 05-08-2020, 10:46 AM
RE: 40-155 tuner grommets - by Squid100 - 05-08-2020, 11:02 AM
RE: 40-155 tuner grommets - by Nathan Slingerland - 05-08-2020, 11:43 AM
RE: 40-155 tuner grommets - by Squid100 - 05-08-2020, 12:07 PM
Philco 91 Tuning Condenser
