  • 1 Vote(s) - 3 Average
40-155 tuner grommets
That's it. Thank you very much for your reply and assistance. Being that the listing mentions the 40-180, which is close in model number to mine, I think I'll take a chance on them.
40-155 tuner grommets - by Squid100 - 05-07-2020, 11:05 PM
RE: 40-155 tuner grommets - by Nathan Slingerland - 05-08-2020, 10:46 AM
RE: 40-155 tuner grommets - by Squid100 - 05-08-2020, 11:02 AM
RE: 40-155 tuner grommets - by Nathan Slingerland - 05-08-2020, 11:43 AM
RE: 40-155 tuner grommets - by Squid100 - 05-08-2020, 12:07 PM
Philco 91 Tuning Condenser
