philco model pt-4
Look at the service info for the PT-4:
36-1533 is the field coil of the electrodynamic speaker (this is before the days where they could cost effectively make strong permanent magnets). The field coil doubled as part of the original filtering design.
philco model pt-4 - by tonto007 - 05-08-2020, 10:18 PM
RE: philco model pt-4 - by Radioroslyn - 05-09-2020, 04:41 AM
RE: philco model pt-4 - by tonto007 - 05-09-2020, 09:43 AM
RE: philco model pt-4 - by Nathan Slingerland - 05-09-2020, 10:21 AM
RE: philco model pt-4 - by Radioroslyn - 05-09-2020, 11:04 AM
RE: philco model pt-4 - by tonto007 - 05-09-2020, 11:30 AM
RE: philco model pt-4 - by Radioroslyn - 05-09-2020, 11:37 AM
RE: philco model pt-4 - by tonto007 - 05-09-2020, 11:47 AM
RE: philco model pt-4 - by Radioroslyn - 05-09-2020, 11:54 AM
RE: philco model pt-4 - by Radioroslyn - 05-09-2020, 12:08 PM
Philco 91 Tuning Condenser
There are currently 9669 online users. [Complete List]
» 1 Member(s) | 9668 Guest(s)
