Zenith 12-S-265 (chassis 1204)
Mike, they are through holes and the board is fairly thick and not very flexible.
When you buy something like this on eBay sometimes it's a crap shoot on whether what you get is as pictured/described or even what you really wanted. This is one time I was not disappointed.
Building the new candohm is probably one of the first things I'll do so I'll take pictures and let everyone know how it turns out.
Zenith 12-S-265 (chassis 1204) - by Eliot Ness - 05-08-2020, 06:51 PM
RE: Zenith 12-S-265 (chassis 1204) - by morzh - 05-08-2020, 08:22 PM
RE: Zenith 12-S-265 (chassis 1204) - by morzh - 05-09-2020, 01:45 PM
RE: Zenith 12-S-265 (chassis 1204) - by Eliot Ness - 05-09-2020, 02:47 PM
RE: Zenith 12-S-265 (chassis 1204) - by morzh - 05-09-2020, 03:01 PM
RE: Zenith 12-S-265 (chassis 1204) - by morzh - 05-09-2020, 04:52 PM
RE: Zenith 12-S-265 (chassis 1204) - by KCMike - 05-11-2020, 05:28 PM
RE: Zenith 12-S-265 (chassis 1204) - by rfeenstra - 05-22-2020, 04:09 PM
RE: Zenith 12-S-265 (chassis 1204) - by morzh - 05-23-2020, 11:22 AM
RE: Zenith 12-S-265 (chassis 1204) - by morzh - 05-23-2020, 12:06 PM
RE: Zenith 12-S-265 (chassis 1204) - by rfeenstra - 05-23-2020, 01:15 PM
RE: Zenith 12-S-265 (chassis 1204) - by morzh - 06-12-2020, 06:57 PM
Philco 91 Tuning Condenser
There are currently 10073 online users. [Complete List]
» 1 Member(s) | 10072 Guest(s)
