Atwater Kent Speaker Question
Is an Atwater Kent model 87-89 speaker a possible replacement for an Atwater Kent model 83-85-86 speaker?
I thought I'd try the easy way out with a question to the expert world while I try to find out the answer the hard way at the same time.
I have the 83-85-86 but it needs to be re-coned.  Any suggestions on re-coning or where to get it done would be nice too.
Atwater Kent Speaker Question - by de371 - 05-10-2020, 08:05 PM
RE: Atwater Kent Speaker Question - by morzh - 05-10-2020, 09:04 PM
RE: Atwater Kent Speaker Question - by de371 - 05-11-2020, 06:30 PM
