  • 2 Vote(s) - 3.5 Average
37-116 Restoration
There is no reason.
It seems it was popular for low values to be wire-wound.
37-116 Restoration - by Greg - 02-08-2020, 12:26 AM
RE: 37-116 Restoration - by truePhilco - 02-08-2020, 09:00 AM
RE: 37-116 Restoration - by Jake Blake - 02-08-2020, 09:39 AM
RE: 37-116 Restoration - by truePhilco - 02-08-2020, 10:17 AM
RE: 37-116 Restoration - by Radioroslyn - 02-08-2020, 12:34 PM
RE: 37-116 Restoration - by Phlogiston - 02-08-2020, 12:45 PM
RE: 37-116 Restoration - by Greg - 03-02-2020, 06:13 PM
RE: 37-116 Restoration - by Radioroslyn - 03-02-2020, 06:58 PM
RE: 37-116 Restoration - by rfeenstra - 03-02-2020, 07:54 PM
RE: 37-116 Restoration - by Greg - 03-02-2020, 08:39 PM
RE: 37-116 Restoration - by rfeenstra - 03-03-2020, 12:11 AM
RE: 37-116 Restoration - by Greg - 03-21-2020, 12:31 PM
RE: 37-116 Restoration - by rfeenstra - 03-21-2020, 07:13 PM
RE: 37-116 Restoration - by Greg - 03-28-2020, 12:23 PM
RE: 37-116 Restoration - by rfeenstra - 03-28-2020, 01:24 PM
RE: 37-116 Restoration - by Greg - 05-13-2020, 11:00 PM
RE: 37-116 Restoration - by 462ron - 05-14-2020, 08:35 AM
RE: 37-116 Restoration - by morzh - 05-14-2020, 10:20 AM
RE: 37-116 Restoration - by 462ron - 05-15-2020, 07:13 AM
RE: 37-116 Restoration - by Radioroslyn - 05-15-2020, 09:35 AM
RE: 37-116 Restoration - by morzh - 05-15-2020, 01:08 PM
RE: 37-116 Restoration - by Greg - 07-21-2020, 10:04 PM
RE: 37-116 Restoration - by Greg - 08-02-2020, 12:20 PM
RE: 37-116 Restoration - by Phlogiston - 08-02-2020, 02:38 PM
RE: 37-116 Restoration - by Greg - 08-14-2020, 06:37 PM
RE: 37-116 Restoration - by Greg - 08-16-2020, 09:46 PM
RE: 37-116 Restoration - by Nathan Slingerland - 08-16-2020, 10:03 PM
RE: 37-116 Restoration - by Greg - 08-16-2020, 10:44 PM
RE: 37-116 Restoration - by rfeenstra - 08-17-2020, 12:24 AM
RE: 37-116 Restoration - by Nathan Slingerland - 08-17-2020, 12:42 AM
RE: 37-116 Restoration - by rfeenstra - 08-17-2020, 01:43 AM
RE: 37-116 Restoration - by Greg - 09-12-2020, 07:42 PM
RE: 37-116 Restoration - by Greg - 10-25-2020, 08:39 PM
RE: 37-116 Restoration - by rfeenstra - 10-26-2020, 12:14 AM
RE: 37-116 Restoration - by morzh - 10-26-2020, 11:28 AM
RE: 37-116 Restoration - by Radioroslyn - 10-26-2020, 11:43 AM
RE: 37-116 Restoration - by KCMike - 10-26-2020, 02:11 PM
RE: 37-116 Restoration - by Greg - 04-04-2021, 07:57 PM
RE: 37-116 Restoration - by Greg - 04-05-2021, 09:19 PM
RE: 37-116 Restoration - by rfeenstra - 04-05-2021, 11:43 PM
RE: 37-116 Restoration - by Greg - 04-06-2021, 08:38 PM
RE: 37-116 Restoration - by rfeenstra - 04-06-2021, 10:37 PM
RE: 37-116 Restoration - by Greg - 08-07-2021, 01:10 PM
RE: 37-116 Restoration - by Phlogiston - 08-07-2021, 01:45 PM
RE: 37-116 Restoration - by Phlogiston - 08-07-2021, 01:48 PM
RE: 37-116 Restoration - by morzh - 08-07-2021, 02:32 PM
RE: 37-116 Restoration - by Greg - 08-07-2021, 03:46 PM
RE: 37-116 Restoration - by Greg - 08-07-2021, 04:23 PM
RE: 37-116 Restoration - by Greg - 08-22-2021, 04:48 PM
RE: 37-116 Restoration - by mikethedruid - 08-22-2021, 06:00 PM
RE: 37-116 Restoration - by Greg - 02-28-2022, 12:04 AM
RE: 37-116 Restoration - by mikethedruid - 02-28-2022, 02:18 AM
RE: 37-116 Restoration - by Greg - 02-28-2022, 08:44 PM
RE: 37-116 Restoration - by Paul Philco322 - 02-28-2022, 08:56 PM
RE: 37-116 Restoration - by GarySP - 02-28-2022, 11:10 PM
RE: 37-116 Restoration - by mikethedruid - 02-28-2022, 11:35 PM
RE: 37-116 Restoration - by PhilcoJohn - 03-01-2022, 07:19 AM
Users browsing this thread: 18 Guest(s)
So, I sat down, and first tried 40 AWG wire. It broke quickly. I retook diameter: this one was 0.05mm whereas the one I ...morzh — 08:24 PM
This is the replacement guide for transistors by GE parts. So, GE-3 is your power replacement for AR14 Just ...morzh — 04:57 PM
Philco 91 Restore Code ??
How do I know if AVC is OK? For the compensator cap I settled on 330pf. Its much closer now and close enough for me. I ...dconant — 04:46 PM
If the small signal ones, take any Ge transistor with unity gain good enough and Vce max 30 or so V. For the output....y...morzh — 03:43 PM
Yes, Michael. This winter I repaired this Westinghouse, RCA 121 and Zenit 5S29. All that remains is to veneer the Zenit ...RadioSvit — 03:28 PM
Thank you. I have one board completely de-populated. Just looking for the correct values. I'll let you know. Still h...R3Sons — 03:13 PM
Is this the one from the Fall Kutztown 2023?morzh — 02:59 PM
If it does not get narrower with strong signal and your AVC is OK, it could veru well be that the shadowgraph's magnet i...morzh — 02:58 PM
The width does not get narrower with generator. I think I will try some other cap values.dconant — 02:56 PM
410pF is a large capacitance to parallel to a compensator. As for the shadowmeter....yes, 3/8" is a bit wide, bu...morzh — 02:49 PM
There are currently 2950 online users. [Complete List]
» 2 Member(s) | 2948 Guest(s)
