Sleuths unite!
Ok I'll start the ball rolling I think it's a 620 from 1936.
Could use a 6A7,75, 80, and a 42 tube.
Sleuths unite! - by OldRestorer - 05-15-2020, 08:46 PM
RE: Sleuths unite! - by Radioroslyn - 05-15-2020, 11:31 PM
RE: Sleuths unite! - by radiohenry - 05-16-2020, 08:10 AM
RE: Sleuths unite! - by GarySP - 05-16-2020, 09:06 AM
RE: Sleuths unite! - by OldRestorer - 05-16-2020, 09:11 PM
RE: Sleuths unite! - by Radioroslyn - 05-17-2020, 11:11 AM
There are currently 10792 online users. [Complete List]
» 2 Member(s) | 10790 Guest(s)
