Philco Tropic?
Interesting - the cabinet looks like the 46-1201:
https://philcoradio.com/gallery2/1946a/#Model_46-1201
But the dial is different and yours has three knobs.
The info on 1946 tropic models is here:
https://philcoradio.com/library/index.ph...ic-models/
But I don't see your model.
However I think I may have found it in the 1948/1949 service info yearbook:
https://philcoradio.com/library/index.ph...year-book/
https://philcoradio.com/library/download...8-1949.pdf
Model 48-1805.
Philco Tropic? - by funkyfize - 05-17-2020, 05:58 PM
RE: Philco Tropic? - by Nathan Slingerland - 05-17-2020, 10:02 PM
RE: Philco Tropic? - by morzh - 05-17-2020, 10:39 PM
RE: Philco Tropic? - by Nathan Slingerland - 05-18-2020, 12:01 AM
RE: Philco Tropic? - by Radioroslyn - 05-18-2020, 11:33 AM
RE: Philco Tropic? - by funkyfize - 05-18-2020, 11:52 AM
RE: Philco Tropic? - by Radioroslyn - 05-18-2020, 12:43 PM
There are currently 9949 online users. [Complete List]
» 1 Member(s) | 9948 Guest(s)
