output transformers
You'll have to open the winding up and measure the diameter of the primary wire. Best guess it's going to be pretty small like 40-50ga. Once you know the size you can determine the length.
output transformers - by loneddie - 05-18-2020, 12:55 PM
RE: output transformers - by Radioroslyn - 05-18-2020, 02:00 PM
RE: output transformers - by morzh - 05-18-2020, 02:30 PM
RE: output transformers - by loneddie - 05-18-2020, 08:46 PM
RE: output transformers - by loneddie - 05-18-2020, 08:48 PM
RE: output transformers - by Brad Winder - 05-23-2020, 10:39 AM
RE: output transformers - by morzh - 05-23-2020, 11:17 AM
Philco 91 Tuning Condenser
There are currently 9849 online users. [Complete List]
» 1 Member(s) | 9848 Guest(s)
