Philco 48-1805 3rd eye or knob...
If you are speaking of the glass thing with numbers on it it's known as the dial. The dial on your set is not the original. It's from a different set. The holes are where the knobs were fitted on whatever set it came from.
RE: Philco 48-1805 3rd eye or knob... - by Radioroslyn - 05-18-2020, 08:56 PM
