37-620 voltages
All transformers are not 100% efficient and the power lost is heat. So maybe it's 2 watts but the transformer is connected to power all the time.
37-620 voltages - by loneddie - 05-18-2020, 09:15 PM
RE: 37-620 voltages - by RodB - 05-19-2020, 09:20 AM
RE: 37-620 voltages - by morzh - 05-19-2020, 09:37 AM
RE: 37-620 voltages - by RodB - 05-19-2020, 10:14 AM
RE: 37-620 voltages - by morzh - 05-19-2020, 10:35 AM
RE: 37-620 voltages - by RodB - 05-19-2020, 10:58 AM
RE: 37-620 voltages - by loneddie - 05-19-2020, 02:45 PM
RE: 37-620 voltages - by morzh - 05-19-2020, 02:51 PM
RE: 37-620 voltages - by loneddie - 05-21-2020, 04:39 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 05:54 PM
RE: 37-620 voltages - by morzh - 05-21-2020, 06:18 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 06:30 PM
RE: 37-620 voltages - by morzh - 05-21-2020, 06:42 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 08:19 PM
RE: 37-620 voltages - by morzh - 05-21-2020, 08:34 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 09:08 PM
Eico 232 VTVM Schematic
There are currently 8024 online users. [Complete List]
» 1 Member(s) | 8023 Guest(s)
