37-620 voltages
Thank you so much for this information. Two things I never thought about: 1. Never heard about a bucking transformer, but will research that. 2. Voltage dropping resistor in the primary sounds swell. But, what does lowering the transformer voltage do to the voltages that are already too low? Like the plate voltages on the 6K7's or the 6A8?
37-620 voltages - by loneddie - 05-18-2020, 09:15 PM
RE: 37-620 voltages - by RodB - 05-19-2020, 09:20 AM
RE: 37-620 voltages - by morzh - 05-19-2020, 09:37 AM
RE: 37-620 voltages - by RodB - 05-19-2020, 10:14 AM
RE: 37-620 voltages - by morzh - 05-19-2020, 10:35 AM
RE: 37-620 voltages - by RodB - 05-19-2020, 10:58 AM
RE: 37-620 voltages - by loneddie - 05-19-2020, 02:45 PM
RE: 37-620 voltages - by morzh - 05-19-2020, 02:51 PM
RE: 37-620 voltages - by loneddie - 05-21-2020, 04:39 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 05:54 PM
RE: 37-620 voltages - by morzh - 05-21-2020, 06:18 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 06:30 PM
RE: 37-620 voltages - by morzh - 05-21-2020, 06:42 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 08:19 PM
RE: 37-620 voltages - by morzh - 05-21-2020, 08:34 PM
RE: 37-620 voltages - by Radioroslyn - 05-21-2020, 09:08 PM
