Another Philco 515 found!
It's never impossible for a rare radio to be floating around out there. There could be a Centry of Progress Philco model just waiting for someone to discover it out there! I've had my share of rare finds both radio and in antique machinery. I have a tiny console radio that appears to be the only one of its kind left. An Air Queen built by Air King.
Another Philco 515 found! - by Ron Ramirez - 02-07-2011, 05:33 PM
Re: Another Philco 515 found! - by Steve Chambers - 02-07-2011, 09:08 PM
Re: Another Philco 515 found! - by Ron Ramirez - 02-07-2011, 09:37 PM
Re: Another Philco 515 found! - by Jayce - 02-08-2011, 02:30 PM
Re: Another Philco 515 found! - by TA Forbes - 02-08-2011, 09:41 PM
Re: Another Philco 515 found! - by Philco1928 - 06-13-2011, 07:36 PM
Re: Another Philco 515 found! - by Arran - 06-14-2011, 12:05 AM
Re: Another Philco 515 found! - by BILL - 06-14-2011, 10:13 AM
Re: Another Philco 515 found! - by FStephenMasek - 06-14-2011, 08:45 PM
Re: Another Philco 515 found! - by Ron Ramirez - 06-14-2011, 09:19 PM
Re: Another Philco 515 found! - by Arran - 06-15-2011, 12:33 AM
Re: Another Philco 515 found! - by FStephenMasek - 06-15-2011, 05:59 PM
Re: Another Philco 515 found! - by Arran - 06-15-2011, 11:58 PM
Re: Another Philco 515 found! - by Marsupial - 06-16-2011, 12:18 AM
Re: Another Philco 515 found! - by Ron Ramirez - 06-16-2011, 06:40 AM
Philco 91 Tuning Condenser
There are currently 10080 online users. [Complete List]
» 2 Member(s) | 10078 Guest(s)
