Mikes, Sams, and Terry's Cabinet restoration chronicles
Threads: 310
City: Kings Park NY
Today I traced, cut, trimmed, glued, ironed, and Grainfilled. ![Icon_crazy Icon_crazy](https://philcoradio.com/phorum/images/smilies/icon_crazy.gif)
The last veneering job is reveneering the lid of Sams philco.
Here is Terrys Chairside thus far...
I think I might leave the original face.... It is real nice but I need Terry's ok.. TERRY!!!!
AC: 4 DC: 1
RE: Mikes, Sams, and Terry's Cabinet restoration chronicles - by OldRestorer - 05-19-2020, 06:58 PM
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 9631 online users. [Complete List] » 1 Member(s) | 9630 Guest(s)
