Mikes, Sams, and Terry's Cabinet restoration chronicles
Threads: 310
City: Kings Park NY
Ill see if the seam can be deleted. If not i'll strip and redo.
Today I decided instead of starting another radio I would keep going on this one.
I grain filled the cabinet this morning so while it dries i'll start gluing Sams combo unit...
Image(s)
AC: 4 DC: 1
RE: Mikes, Sams, and Terry's Cabinet restoration chronicles - by OldRestorer - 05-20-2020, 10:26 AM
Here are the links. 6TPZ and 5TPO
The speakers are good. I've tried several known good ones. I just have to fi...R3Sons — 06:27 PM
Philco 91 Tuning Condenser
Hello,
Does anyone know how the dial plate comes off the tuning condenser shaft? The dial itself id so warped I can't...dconant — 06:01 PM
Ron,
for the future:
1. Go to the very first post.
2. Hit "Edit...morzh — 04:29 PM
Transistors are easy.
Or touch your fin...morzh — 04:25 PM
Ron
Instead of Quick reply, go to New Reply, then go to the title of the very first post, and change the title text the...morzh — 02:00 PM
I am not a specialist in car radios.
I suspect they might use vibrators to convert 12V to acceptable tube voltages, so ...morzh — 01:58 PM
