Mikes, Sams, and Terry's Cabinet restoration chronicles
Does look like there is some contrast between the corner sections (lighter) and mid sections.
https://philcoradio.com/gallery2/1935a/#Model_16RX
To me I would lighten center section and tone the burl a little darker to match the lighten center.
Pics 3-5 have been refinished so they don't count. Looks like the decal (s) is on upside down and it's posed backwards.
The dial (printed upside down) is set up like the 660L where is closest to the operator and the knobs are above. It's
a little counter intuitive.
RE: Mikes, Sams, and Terry's Cabinet restoration chronicles - by Radioroslyn - 05-20-2020, 06:04 PM
Philco 91 Tuning Condenser
