Mikes, Sams, and Terry's Cabinet restoration chronicles
#37
I see...one of those "getting stubborn with age" cases.
Let's hope nothing is broken.
RE: Mikes, Sams, and Terry's Cabinet restoration chronicles - by morzh - 05-30-2020, 06:26 PM
Philco 91 Tuning Condenser
