38-116 code 125 volume issues
Injected audio at volume control, Sounds like crap. took volume control out of the test and it still sounds like crap.
it is def in the audio section. I have to trace this all down.
Volume control is good.
As a test I pulled one of the 6l6 to run it with one and got distorted sound. swapped tubes between sockets and got same issue.
tracing on.....
38-116 code 125 volume issues - by simplex1040 - 05-28-2020, 09:59 AM
RE: 38-116 code 125 volume issues - by morzh - 05-28-2020, 11:15 AM
RE: 38-116 code 125 volume issues - by simplex1040 - 05-30-2020, 06:31 PM
RE: 38-116 code 125 volume issues - by morzh - 05-30-2020, 08:33 PM
RE: 38-116 code 125 volume issues - by morzh - 05-30-2020, 10:22 PM
RE: 38-116 code 125 volume issues - by morzh - 05-30-2020, 11:10 PM
RE: 38-116 code 125 volume issues - by morzh - 05-31-2020, 01:55 PM
There are currently 2896 online users. [Complete List]
» 1 Member(s) | 2895 Guest(s)
