38-116 code 125 volume issues
Ok... Remove the 6J5 driver tube and measure the resistance from pin 2 to pin 7 at the tube base not at the socket. Should see a low resistance of a few ohms.
> no ref in voltage chart for bias on the screen on the driver tube. So we shall see.
Good reason for it as the driver tube has no screen grid.
38-116 code 125 volume issues - by simplex1040 - 05-28-2020, 09:59 AM
RE: 38-116 code 125 volume issues - by morzh - 05-28-2020, 11:15 AM
RE: 38-116 code 125 volume issues - by morzh - 05-30-2020, 08:33 PM
RE: 38-116 code 125 volume issues - by morzh - 05-30-2020, 10:22 PM
RE: 38-116 code 125 volume issues - by morzh - 05-30-2020, 11:10 PM
RE: 38-116 code 125 volume issues - by morzh - 05-31-2020, 01:55 PM
RE: 38-116 code 125 volume issues - by Radioroslyn - 06-01-2020, 03:48 PM
There are currently 2925 online users. [Complete List]
» 1 Member(s) | 2924 Guest(s)
