Rogers 10-85 cabinet all done
I like these Rogers radios,especially some of the cabinets.
 I picked this one up last fall and during the winter I did the chassis,
and replaced the top veneer.
 Now I finally got the cabinet done.
 Dan in Calgary
   Living in Calgary Alberta
Rogers 10-85 cabinet all done - by Dan Walker - 06-01-2020, 08:52 PM
RE: Rogers 10-85 cabinet all done - by radiohenry - 06-02-2020, 12:40 PM
RE: Rogers 10-85 cabinet all done - by Phlogiston - 06-02-2020, 04:01 PM
RE: Rogers 10-85 cabinet all done - by Dan Walker - 06-03-2020, 09:42 AM
RE: Rogers 10-85 cabinet all done - by Phlogiston - 06-03-2020, 10:00 AM
RE: Rogers 10-85 cabinet all done - by Dan Walker - 06-05-2020, 09:36 AM
RE: Rogers 10-85 cabinet all done - by Dan Walker - 06-10-2020, 10:17 AM
Philco 91 Tuning Condenser
