What are the correct electrolytics for a 41-280 chassis?
Electrolytics are replaced as of today (2/10/11). Now on to the small caps. And resistors which are out of tolerance....not too many, thank goodness. Found a braided copper wire out of the variable capacitor broken. It was grounded to the chassis. So soldered it back together where it went through a hole in the deck. About the only thing I could do because of crowded locations. Have continuity so think that is solved. Speaker repair done today also. Hopefully will know soon whether this baby is going to play!
Dan; I've seen some Marconi sets like that before, one was a console though I'm not sure if it was a model 86. It's a...Arran — 05:09 PM
Milkjug plastic? Whatever is chosen for the spider, the material must be compatible with popular adhesives... Th...Chas — 05:05 PM
Mike; I would not use plastic from a milk jug for a spider, first it's polyethylene/polypropylene which resists most ...Arran — 04:56 PM
There are currently 5641 online users. [Complete List]
» 3 Member(s) | 5638 Guest(s)
