Zenith 15U270
That Radio is just beautiful, I love the wood on the cabinet. A Zenith radio like that is hard to come by I bet. Enjoy it! I wish I had one just like it. I bet it plays beautifully.  Icon_thumbup
Zenith 15U270 - by rfeenstra - 05-31-2020, 04:45 PM
RE: Zenith 15U270 - by rfeenstra - 05-31-2020, 04:54 PM
RE: Zenith 15U270 - by morzh - 05-31-2020, 06:10 PM
RE: Zenith 15U270 - by rfeenstra - 05-31-2020, 08:06 PM
RE: Zenith 15U270 - by morzh - 05-31-2020, 08:39 PM
RE: Zenith 15U270 - by Eliot Ness - 06-01-2020, 08:07 AM
RE: Zenith 15U270 - by rfeenstra - 06-04-2020, 08:12 PM
RE: Zenith 15U270 - by sdradioman - 06-05-2020, 07:06 AM
RE: Zenith 15U270 - by rfeenstra - 06-05-2020, 10:12 PM
RE: Zenith 15U270 - by morzh - 06-05-2020, 11:44 PM
RE: Zenith 15U270 - by Phlogiston - 06-06-2020, 10:46 AM
RE: Zenith 15U270 - by rfeenstra - 06-06-2020, 11:23 AM
RE: Zenith 15U270 - by rfeenstra - 06-06-2020, 06:23 PM
RE: Zenith 15U270 - by Phlogiston - 06-06-2020, 08:56 PM
RE: Zenith 15U270 - by rfeenstra - 06-06-2020, 09:47 PM
RE: Zenith 15U270 - by Phlogiston - 06-06-2020, 10:34 PM
RE: Zenith 15U270 - by rfeenstra - 06-09-2020, 09:14 PM
RE: Zenith 15U270 - by PhilcoJohn - 06-10-2020, 08:27 AM
RE: Zenith 15U270 - by Phlogiston - 06-11-2020, 11:32 AM
RE: Zenith 15U270 - by rfeenstra - 06-11-2020, 03:31 PM
There are currently 9273 online users. [Complete List]
» 2 Member(s) | 9271 Guest(s)
