Zenith 15U270
Yes, and they are not a "dime/dozen" - if you could find a dozen.
I was just dealing with a rare radio, so rare that it has not been properly identified, anywhere. It has a crack in the arc on the right side. Not large, but you can see it if you look - and I do. It was caused by poor construction. It looks like they left a gap along that whole arc making the bent plywood unstable. I could have fixed it. It would have required the replacement of the front/sides along with the veneer - so probably about half the cabinet or about 3/4 of what a person sees. If these were common, it would have been OK to fix, but, on a rare radio it was better to make it look as good as possible and try to look elsewhere as I walk by.
More to come on Parmak 525.
Russ
Zenith 15U270 - by rfeenstra - 05-31-2020, 04:45 PM
RE: Zenith 15U270 - by rfeenstra - 05-31-2020, 04:54 PM
RE: Zenith 15U270 - by morzh - 05-31-2020, 06:10 PM
RE: Zenith 15U270 - by rfeenstra - 05-31-2020, 08:06 PM
RE: Zenith 15U270 - by morzh - 05-31-2020, 08:39 PM
RE: Zenith 15U270 - by Eliot Ness - 06-01-2020, 08:07 AM
RE: Zenith 15U270 - by rfeenstra - 06-04-2020, 08:12 PM
RE: Zenith 15U270 - by sdradioman - 06-05-2020, 07:06 AM
RE: Zenith 15U270 - by rfeenstra - 06-05-2020, 10:12 PM
RE: Zenith 15U270 - by morzh - 06-05-2020, 11:44 PM
RE: Zenith 15U270 - by Phlogiston - 06-06-2020, 10:46 AM
RE: Zenith 15U270 - by rfeenstra - 06-06-2020, 11:23 AM
RE: Zenith 15U270 - by rfeenstra - 06-06-2020, 06:23 PM
RE: Zenith 15U270 - by Phlogiston - 06-06-2020, 08:56 PM
RE: Zenith 15U270 - by rfeenstra - 06-06-2020, 09:47 PM
RE: Zenith 15U270 - by Phlogiston - 06-06-2020, 10:34 PM
RE: Zenith 15U270 - by rfeenstra - 06-09-2020, 09:14 PM
RE: Zenith 15U270 - by PhilcoJohn - 06-10-2020, 08:27 AM
RE: Zenith 15U270 - by Phlogiston - 06-11-2020, 11:32 AM
RE: Zenith 15U270 - by rfeenstra - 06-11-2020, 03:31 PM
Philco 91 Tuning Condenser
There are currently 10539 online users. [Complete List]
» 2 Member(s) | 10537 Guest(s)
