I made bubbles!
Emerson used a plastic strip as a trim in a lot of their radios and I got frustrated searching for a replacement. I filled in the groove with wood putty then sanded, masked and dark stain. Or you can skip the mask by adding the stain to the putty. Might even use black paint.
I made bubbles! - by pokey - 06-12-2020, 03:10 PM
RE: I made bubbles! - by RodB - 06-12-2020, 03:38 PM
RE: I made bubbles! - by Phlogiston - 06-12-2020, 04:06 PM
RE: I made bubbles! - by pokey - 06-12-2020, 06:03 PM
