1941 GE Model L-640 Help Needed
Here is the dial stringing diagram complements of radiomuseum.org:
On the OT & speaker you can get the plate impedance of the audio output tube and find a universal transformer with a primary impedance close to the tube.  That should match to a 3.2 ohm speaker. Don't have any answers for the antenna.  If you wait for a junker chassis you will probably wait a long time and then you may have competition.  Best thing to do is get it running now and buy the junker if it comes along.
Rod
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-19-2020, 09:29 AM
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-19-2020, 07:15 PM
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-20-2020, 05:02 PM
