1941 GE Model L-640 Help Needed
> transformer with a primary impedance close to the tube.
Something around 5-7K is good. An AA5 transformer is too low as it's around 2K.
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-19-2020, 09:29 AM
RE: 1941 GE Model L-640 Help Needed - by Radioroslyn - 06-19-2020, 12:38 PM
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-19-2020, 07:15 PM
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-20-2020, 05:02 PM
Philco 91 Tuning Condenser
There are currently 9773 online users. [Complete List]
» 1 Member(s) | 9772 Guest(s)
