1941 GE Model L-640 Help Needed
These are new speakers from Parts Express and you have to be aware of the mounting holes matching your mounting studs. A new 5" speaker is not the same size as the old 5".
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-19-2020, 09:29 AM
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-19-2020, 07:15 PM
RE: 1941 GE Model L-640 Help Needed - by RodB - 06-20-2020, 05:02 PM
Philco 91 Tuning Condenser
