Philco 42-327 no reception on the three Bands
>I checked the continuity on the Oscillator pin 4-6 and unfortunately there is not continuity!!!
So the next step to do would be to measure the resistance from pins 4 to 5 then 5 to 3 then 3 to 6. All should measure a near dead short. This will determine which section has the fault. If you are lucky the winding will be one layer wound flat onto the form so spotting the problem will be easier than if it was several layers on top of one another. Also the SW winding is somewhat smaller (less turns) than the the bc band. The bc band would be around 90 turns and your sw band would be about 30 turns.
The faults would be a break the wire or a green dot indicating rot.
Happy Hunting!
RE: Philco 42-327 no reception on the three Bands - by Radioroslyn - 06-21-2020, 07:18 AM
Philco 49-1040
Philco 49-1040
