1942 Zenith 10S690 belt and pulley issues
OK, so I have an issue that just popped up with my Zenith radio, I just finished recapping the radio and went to test it out and for some reason the volume control is acting like a tone control knob rather than a volume control knob and I tried to pay attention to where all the caps went and everything, and I can't figure out where the volume control and tone control circuits are on the schematic to see if I may have wired something up wrong or put a wrong value capacitor in somewhere.
Other than that everything is working as it should.
Any help would be appreciated in this matter.
See schematic below.
.pdf Zenith 10S690 Service Manual_Riders.pdf Size: 190.41 KB  Downloads: 227
RE: 1942 Zenith 10S690 belt and pulley issues - by captainclock1988 - 06-23-2020, 12:13 PM
There are currently 9955 online users. [Complete List]
» 2 Member(s) | 9953 Guest(s)
