Is the RCA 9k radio console a rarity and how many have been made?
Hi to all. Please help with the information ... Recently I accidentally and in rather bad condition bought the RCA 9k radio console and I am very interested in information about the number of copies of this model and whether it is currently a rarity among collectors? Thanks for any information.
Philco 91 Tuning Condenser
