RCA 1X591 hum problem
Ok, checked the coupling capacitor between the 12SQ7 and the 50L6. It's value on the schematic is a .0022uf. When I hold the capacitor between my fingers, the radio plays loud and clear with 2 different 50L6 tubes, but when I release the capacitor slowly, the loud hum/buzz returns. What do you think??? Oh, what I believe to be the original wax/paper capacitor at .0022uf @400 volts was in the radio.
RCA 1X591 hum problem - by Tubeglow20 - 06-27-2020, 10:24 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-27-2020, 10:57 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 11:58 AM
RE: RCA 1X591 hum problem - by RodB - 06-28-2020, 12:49 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-28-2020, 01:26 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 03:23 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 06:38 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-28-2020, 06:51 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 07:00 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-28-2020, 07:19 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-29-2020, 05:18 PM
RE: RCA 1X591 hum problem - by Paul Philco322 - 06-29-2020, 08:20 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-30-2020, 02:30 PM
RE: RCA 1X591 hum problem - by Paul Philco322 - 06-30-2020, 03:07 PM
RE: RCA 1X591 hum problem - by Eliot Ness - 06-30-2020, 03:38 PM
RE: RCA 1X591 hum problem - by MrFixr55 - 07-25-2020, 08:39 AM
Philco 91 Tuning Condenser
There are currently 9796 online users. [Complete List]
» 1 Member(s) | 9795 Guest(s)
