RCA 1X591 hum problem
Well if you think more capacitance will help go ahead add some.
A .005 or .01 is fine. There isn't much voltage there even a 100v
cap would be fine. The .002 might have been used as a tradeoff
to roll off some of the low frequency response. By increasing it
value may increase the hum level.
One other thing use a GT style 12SQ7. Have seen where pin 1
was used as a tie point, not a good idea when using metal tubes.
RCA 1X591 hum problem - by Tubeglow20 - 06-27-2020, 10:24 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-27-2020, 10:57 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 11:58 AM
RE: RCA 1X591 hum problem - by RodB - 06-28-2020, 12:49 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-28-2020, 01:26 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 03:23 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 06:38 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-28-2020, 06:51 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-28-2020, 07:00 PM
RE: RCA 1X591 hum problem - by Radioroslyn - 06-28-2020, 07:19 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-29-2020, 05:18 PM
RE: RCA 1X591 hum problem - by Paul Philco322 - 06-29-2020, 08:20 PM
RE: RCA 1X591 hum problem - by Tubeglow20 - 06-30-2020, 02:30 PM
RE: RCA 1X591 hum problem - by Paul Philco322 - 06-30-2020, 03:07 PM
RE: RCA 1X591 hum problem - by Eliot Ness - 06-30-2020, 03:38 PM
RE: RCA 1X591 hum problem - by MrFixr55 - 07-25-2020, 08:39 AM
There are currently 8814 online users. [Complete List]
» 2 Member(s) | 8812 Guest(s)
