32v Battery eliminator
Found a picture hope this helps David     http://philcoradio.com/gallery2/1935a/#Model_32B
32v Battery eliminator - by Scott D - 06-30-2020, 04:22 PM
RE: 32v Battery eliminator - by David - 06-30-2020, 07:20 PM
RE: 32v Battery eliminator - by Paul Philco322 - 06-30-2020, 09:08 PM
RE: 32v Battery eliminator - by Scott D - 06-30-2020, 09:47 PM
RE: 32v Battery eliminator - by sdradioman - 07-01-2020, 12:03 AM
RE: 32v Battery eliminator - by Ron Ramirez - 07-01-2020, 09:55 AM
RE: 32v Battery eliminator - by Scott D - 07-01-2020, 08:04 PM
RE: 32v Battery eliminator - by PhilcoPhan1936 - 07-17-2020, 07:37 PM
