32v Battery eliminator
Thanks Ron!  I wondered if that was original.  The set has been converted and works marvelously.
Take care and blessings.  Praying for you!
Scott
32v Battery eliminator - by Scott D - 06-30-2020, 04:22 PM
RE: 32v Battery eliminator - by David - 06-30-2020, 07:20 PM
RE: 32v Battery eliminator - by Paul Philco322 - 06-30-2020, 09:08 PM
RE: 32v Battery eliminator - by Scott D - 06-30-2020, 09:47 PM
RE: 32v Battery eliminator - by sdradioman - 07-01-2020, 12:03 AM
RE: 32v Battery eliminator - by Ron Ramirez - 07-01-2020, 09:55 AM
RE: 32v Battery eliminator - by Scott D - 07-01-2020, 08:04 PM
RE: 32v Battery eliminator - by PhilcoPhan1936 - 07-17-2020, 07:37 PM
There are currently 10352 online users. [Complete List]
» 1 Member(s) | 10351 Guest(s)
