Parmak Farm Radio
Thanks guys.
I am about a day away from buffing out the 5-F-134 cabinet. This is the 2nd farm radio - the one that needed to have the chassis replated.
Since I was doing one chassis, I decided to replat a 5-S-127 chassis as well. On it the variable cap and IF transformer covers were done as well. I had mentioned zinc plating previously. This chassis will also fit in the same Zenith cabinet.
I will add it to the blog asap.
Parmak Farm Radio - by Phlogiston - 06-22-2020, 09:08 PM
RE: Parmak Farm Radio - by Eliot Ness - 06-23-2020, 11:29 AM
RE: Parmak Farm Radio - by Phlogiston - 06-23-2020, 04:34 PM
RE: Parmak Farm Radio - by klondike98 - 07-05-2020, 01:07 AM
RE: Parmak Farm Radio - by Paul Philco322 - 07-05-2020, 11:50 AM
RE: Parmak Farm Radio - by morzh - 07-05-2020, 12:10 PM
RE: Parmak Farm Radio - by Phlogiston - 07-05-2020, 04:17 PM
RE: Parmak Farm Radio - by rfeenstra - 07-05-2020, 08:54 PM
RE: Parmak Farm Radio - by Phlogiston - 07-06-2020, 10:20 AM
RE: Parmak Farm Radio - by rfeenstra - 07-06-2020, 10:56 AM
Philco 91 Tuning Condenser
There are currently 9784 online users. [Complete List]
» 1 Member(s) | 9783 Guest(s)
