610 Console
Mine has 2 speaker screws imbedded in the center bar of the 3 bars that form the grillework. The other two screws are the standard 37 type that go through the face of the radio to secure the speaker.
610 Console - by 7estatdef - 02-13-2011, 02:58 PM
Re: 610 Console - by TA Forbes - 02-13-2011, 03:07 PM
There are currently 10545 online users. [Complete List]
» 2 Member(s) | 10543 Guest(s)
