GE 513f
Looked the model number up have one. Picked up at local flea with a crack in the top color is red. GE made several model of the same basic design. Different models for different colors. Some models will have small changes around the 12BE6. Fun radio not bad for a AA5.   http://www.nostalgiaair.org/Resources/696/M0007696.htm
GE 513f - by jcassity - 07-13-2020, 03:42 PM
RE: GE 513f - by David - 07-13-2020, 04:10 PM
RE: GE 513f - by jcassity - 07-13-2020, 05:17 PM
RE: GE 513f - by David - 07-13-2020, 05:46 PM
RE: GE 513f - by jcassity - 07-13-2020, 05:47 PM
RE: GE 513f - by David - 07-13-2020, 08:54 PM
RE: GE 513f - by Chas - 07-13-2020, 11:46 PM
Philco 91 Tuning Condenser
There are currently 8612 online users. [Complete List]
» 2 Member(s) | 8610 Guest(s)
