GE 513f
the site does not list 12av6
my sylvania cross ref manual does not either.
google says 12av6 can cross over to 12AT6 12BK6 12BT6 12BU6
sure these may cross but what resistors/caps would need reworked.
or... are these considered direct swaps.
I see its claimed the 12at6 is a direct swap with slightly less amplificaiton.
help
GE 513f - by jcassity - 07-13-2020, 03:42 PM
RE: GE 513f - by David - 07-13-2020, 04:10 PM
RE: GE 513f - by jcassity - 07-13-2020, 05:17 PM
RE: GE 513f - by David - 07-13-2020, 05:46 PM
RE: GE 513f - by jcassity - 07-13-2020, 05:47 PM
RE: GE 513f - by David - 07-13-2020, 08:54 PM
RE: GE 513f - by Chas - 07-13-2020, 11:46 PM
There are currently 7349 online users. [Complete List]
» 1 Member(s) | 7348 Guest(s)
