What radio is this? Never heard of the brand.
Good sleuthing Carl  Icon_thumbup
Unfortunately Electronic Devices Company was most likely just a wholesaler buying radios from one or more radio manufacturers.  Their address, 601 w. 26th St., New York, NY, was built in 1931 as a full-block freight terminal, warehouse and office building.
You can find this ad in the June 1946 issue of Radio and Television Retailing on page 37:
https://worldradiohistory.com/Radio_Reta...gazine.htm
RE: What radio is this? Never heard of the brand. - by Eliot Ness - 07-20-2020, 09:59 AM
Philco 91 Tuning Condenser
There are currently 9875 online users. [Complete List]
» 1 Member(s) | 9874 Guest(s)
