  • 1 Vote(s) - 2 Average
1927 Eveready (National Carbon) Model 1 TRF Radio
I beat the system a little with the wire. I buy less expensive bulk rolls of white (usually cloth braided cover) and keep several different colors of Sharpie felt tip pens around. I then draw a trace color on the white replacement in the color needed. Good luck! Take care and BE HEALTHY! Gary
RE: 1927 Eveready (National Carbon) Model 1 TRF Radio - by GarySP - 07-21-2020, 09:36 AM
Eico 232 VTVM Schematic
There are currently 7650 online users. [Complete List]
» 1 Member(s) | 7649 Guest(s)
