Philco 48-1286 Restoration
Where are you physically located? There may be someone nearby who could help, or even an old radio club.
Replacing the filter capacitors would be a good first step. You will need more than a needle - the crystal cartridge will need to be rebuilt. WestTech is one cartridge rebuilder I have used several times.
Web site: http://www.masekconsulting.net
Radio Photos: http://www.photobucket.com - album id FStephenMasek
Philco 48-1286 Restoration - by daveo91 - 02-14-2011, 10:07 AM
RE: Philco 48-1286 Restoration - by audiomagnate - 07-10-2013, 01:48 PM
Re: Philco 48-1286 Restoration - by FStephenMasek - 02-15-2011, 01:19 AM
Re: Philco 48-1286 Restoration - by daveo91 - 02-16-2011, 10:16 AM
Re: Philco 48-1286 Restoration - by FStephenMasek - 02-16-2011, 10:08 PM
Re: Philco 48-1286 Restoration - by brianclara - 02-17-2011, 08:29 PM
Re: Philco 48-1286 Restoration - by daveo91 - 02-24-2011, 01:25 PM
There are currently 10540 online users. [Complete List]
» 3 Member(s) | 10537 Guest(s)
