Please help with ID and possible repair
Welcome to the Phorum. You should find plenty of help here for your repair. First tip is to never power up one of these vintage units until you have confidence that the power supply is in good shape. The power supply filter capacitors most definitely will have to be replaced as well as other capacitors in the radio. If you don't do this then you can end up damaging transformers, field coils or tubes, some of which are difficult to find. So let's get a look at what you have.
Rod
RE: Please help with ID and possible repair - by RodB - 07-28-2020, 02:52 PM
There are currently 5261 online users. [Complete List]
» 2 Member(s) | 5259 Guest(s)
