Rebuilt 46 Philco dead after one hour!
Take Ron's advice and have all the capacitors replaced. Your radio is a time bomb!
M R Radios   C M Tubes
Re: Rebuilt 46 Philco dead after one hour! - by Steve Davis - 02-17-2011, 12:59 AM
There are currently 10324 online users. [Complete List]
» 2 Member(s) | 10322 Guest(s)
