Looking for Photo - Crosley 425 Table Radio
If you need more photos, Russ, let me know.
I have a Constitution with original finish, I should be able to get you detail photos.
RE: Looking for Photo - Crosley 915 Table Radio - by palegreenthumb - 08-05-2020, 11:14 AM
