  • 1 Vote(s) - 2 Average
1927 Eveready (National Carbon) Model 1 TRF Radio
I'm just going to install a modern axial leaded 47k Ohm 1 Watt resistor onto the terminals below the resistor socket so that way if I do end up finding a 50K Ohm fuse style resistor I can just install it in the socket and just unhook the one underneath.
RE: 1927 Eveready (National Carbon) Model 1 TRF Radio - by captainclock1988 - 08-05-2020, 04:00 PM
Eico 232 VTVM Schematic
There are currently 6466 online users. [Complete List]
» 2 Member(s) | 6464 Guest(s)
