Bakelite block caps
Emptied out the Bakelite block and have the Y2 safety caps on hand.
Just checking that I don't need to worry about polarity.  One lead (doesn't matter which) from each cap through a shared eyelet with no wire connections (i.e., to ground), and the two other leads through one eyelet each.  Is that how it goes?
Bakelite block caps - by pokey - 08-14-2020, 06:39 PM
RE: Bakelite block caps - by EdHolland - 08-14-2020, 06:48 PM
RE: Bakelite block caps - by pokey - 08-14-2020, 07:09 PM
RE: Bakelite block caps - by LarryFS - 08-14-2020, 07:27 PM
RE: Bakelite block caps - by klondike98 - 08-14-2020, 09:23 PM
RE: Bakelite block caps - by fenbach - 08-14-2020, 11:01 PM
RE: Bakelite block caps - by pokey - 08-15-2020, 06:53 AM
RE: Bakelite block caps - by klondike98 - 08-15-2020, 10:27 AM
RE: Bakelite block caps - by pokey - 08-15-2020, 10:36 AM
RE: Bakelite block caps - by PhilcoPhan1936 - 08-15-2020, 11:34 AM
RE: Bakelite block caps - by fenbach - 08-15-2020, 04:46 PM
RE: Bakelite block caps - by pokey - 08-16-2020, 07:52 AM
RE: Bakelite block caps - by Nathan Slingerland - 08-16-2020, 11:42 AM
RE: Bakelite block caps - by Radioroslyn - 08-23-2020, 01:15 AM
RE: Bakelite block caps - by pokey - 08-23-2020, 09:24 AM
There are currently 3088 online users. [Complete List]
» 1 Member(s) | 3087 Guest(s)
