Philco mentor needed
Hi, I recently purchased a neat looking old radio at a garage sale for more of a decorative purpose, turns out that it is a Philco model 38-2xx. The cabinet is absolutely beautiful and in great shape, but the electronics for the most part are all missing other than a metal box with some broken tubes. I would really enjoy restoring it to its original glory, however I don't know much about electronics(i'm a plumber), and I don't want to sink a ton of money into a possibly unsuccessful project. I need a mentor of sorts to guide me in the right direction or tell me that its way too expensive or parts are too hard to find. Thank you in advance.
Philco mentor needed - by nickkozar - 02-19-2011, 03:03 PM
Re: Philco mentor needed - by FStephenMasek - 02-19-2011, 10:42 PM
Re: Philco mentor needed - by Glenn Roberts - 02-20-2011, 06:44 AM
Re: Philco mentor needed - by nickkozar - 02-21-2011, 08:16 PM
Re: Philco mentor needed - by Ron Ramirez - 02-22-2011, 08:59 AM
Re: Philco mentor needed - by JROZ - 10-03-2011, 01:32 PM
There are currently 8433 online users. [Complete List]
» 1 Member(s) | 8432 Guest(s)
