Philco 47-1230 restoration
finally had some time before Church on Sunday to solder up the power cord. Here is a shot of the solders and some of the caps, which I am guessing will need to be replaced.
[Image: http://farm6.static.flickr.com/5176/5464...8520_z.jpg]
photo by robertwsimpson, on Flickr
Codefox1: thanks for your input! I will stick my multimeter on the transformer and see if it is still good.
Philco 47-1230 restoration - by robertwsimpson - 02-11-2011, 09:09 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-11-2011, 02:14 PM
Re: Philco 47-1230 restoration - by TA Forbes - 02-11-2011, 02:37 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-11-2011, 11:11 PM
Re: Philco 47-1230 restoration - by marcapra - 02-12-2011, 12:16 AM
Re: Philco 47-1230 restoration - by Jayce - 02-12-2011, 02:05 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 02-12-2011, 09:31 PM
Re: Philco 47-1230 restoration - by DeckApe - 02-14-2011, 11:04 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 02-15-2011, 09:08 PM
Re: Philco 47-1230 restoration - by codefox1 - 02-18-2011, 06:01 PM
Re: Philco 47-1230 restoration - by robertwsimpson - 02-21-2011, 09:00 AM
Re: Philco 47-1230 restoration - by codefox1 - 02-21-2011, 01:37 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 01:37 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:27 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 02:34 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-22-2011, 11:32 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-22-2011, 11:58 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-23-2011, 10:32 AM
Re: Philco 47-1230 restoration - by ipwizard - 04-28-2011, 06:08 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 09:54 AM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-29-2011, 04:07 PM
Re: Philco 47-1230 restoration - by Marsupial - 04-29-2011, 05:58 PM
Re: Philco 47-1230 restoration - by gary rabbitt - 04-30-2011, 01:22 AM
Re: Philco 47-1230 restoration - by Marsupial - 04-30-2011, 11:45 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 12:03 AM
Re: Philco 47-1230 restoration - by Marsupial - 05-01-2011, 12:48 AM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-01-2011, 07:54 AM
Re: Philco 47-1230 restoration - by ipwizard - 05-01-2011, 10:55 PM
Re: Philco 47-1230 restoration - by Ron Ramirez - 05-05-2011, 09:04 AM
Philco 91 Tuning Condenser
