Philco mentor needed
Hello and welcome!
You are in luck...one of the largest radio clubs in the country is in Michigan, and they host one of the country's largest radio swap meets each July.
I suggest you contact the Michigan Antique Radio Club. I am sure they will have someone who can help you out.
Their website is down, but if you contact Mark Oppat he can give you all of the info.
moppat AT comcast DOT net
Philco mentor needed - by nickkozar - 02-19-2011, 03:03 PM
Re: Philco mentor needed - by FStephenMasek - 02-19-2011, 10:42 PM
Re: Philco mentor needed - by Glenn Roberts - 02-20-2011, 06:44 AM
Re: Philco mentor needed - by nickkozar - 02-21-2011, 08:16 PM
Re: Philco mentor needed - by Ron Ramirez - 02-22-2011, 08:59 AM
Re: Philco mentor needed - by JROZ - 10-03-2011, 01:32 PM
There are currently 10106 online users. [Complete List]
» 1 Member(s) | 10105 Guest(s)
