Magnavox Provincial
Well, then, I'm afraid I can't help you as I am unfamiliar with the Collaro.
But as for getting to the cartridge, as I posted previously, I turned my WC 256 changer upside down on the workbench; and then I could move the tonearm aside just enough to reach the cartridge and change it. But if the Collaro arm won't move aside enough...
Hopefully, Doug Houston will chime in here with some thoughts. If not, you might send him an email; I am sure he will know what to do about your Collaro.
Magnavox Provincial - by PFJC2 - 02-22-2011, 07:45 PM
Re: Magnavox Provincial - by Ron Ramirez - 02-22-2011, 09:59 PM
Re: Magnavox Provincial - by PFJC2 - 02-23-2011, 12:28 AM
Re: Magnavox Provincial - by Ron Ramirez - 02-23-2011, 10:14 AM
Re: Magnavox Provincial - by Doug Houston - 04-17-2011, 12:03 AM
Re: Magnavox Provincial - by PFJC2 - 04-17-2011, 09:15 PM
Re: Magnavox Provincial - by Ron Ramirez - 04-18-2011, 05:43 AM
Re: Magnavox Provincial - by Doug Houston - 04-18-2011, 05:32 PM
Re: Magnavox Provincial - by PFJC2 - 04-20-2011, 04:16 PM
